2000 blazer speed sensors
Old May 4, 2014 | 08:24 PM
lexxman's Avatar
lexxman is on a distinguished road
Default 2000 blazer speed sensors
I have a 2000 blazer, I'm having the problem of just as I'm coming to a stop the brakes will cut in and out. I've been told it's probably the speed sensors , but how can I know for sure and how do I known witch side it is? Any help would be great.
Old Jul 15, 2014 | 03:21 PM
fletch125's Avatar
fletch125 is an unknown quantity at this point
Its very common for the senors to become corroded and falsely engage the ABS system the best thing you can do is hook it up to a scan tool and see which sensor isnt reading by spinning the tires since they read speed the bad sensor will read incorrectly.
Old Jul 15, 2014 | 03:33 PM
^^^ this
had the same issue with mine. used my buddy's scanner at work that could monitor the ABS system and found that I was getting no signal from the front right sensor
contrary to what a lot of people will tell you, you DO NOT have to replace the entire bearing hub assembly just to replace the speed sensor... I replaced the sensor and my ABS light shut off as soon as I started rolling. and to boot, I didn't even use a sensor specifically for my truck, I used one off a mid 2000's full size Chevy truck on my 2004 Blazer 4x4, worked like a charm
jdub9000
Jul 22, 2013 07:58 AM
madblazerowner
Mar 9, 2012 09:46 AM
iamchevyman5
Feb 28, 2011 04:35 PM
procell895c
Tires and Wheels
Jul 15, 2006 11:10 AM
