2000 bravada AWD
Old Jan 23, 2012 | 05:53 PM
chaffinyo's Avatar
chaffinyo is on a distinguished road
Default 2000 bravada AWD
So when I bought my bravada, three weeks ago, it had the service awd light on. So yesterday I replaced the encoder motor after I checked the trouble codes to make sure that is what it was. And today I had to run my niece to school (sister has cancer long story) and living in rural iowa I had some fun on the way home driving down some minimum service roads, and around noon my light is back on. Does anybody know what ths problem could be? Any help would be great
Old Jan 23, 2012 | 07:20 PM
xgiovannix12's Avatar
pull the codes again see if you have the same code
Old Jan 23, 2012 | 11:21 PM
chaffinyo's Avatar
i plan on doing that tomorrow (tuesday) in the am
Old Jan 24, 2012 | 03:18 PM
chaffinyo's Avatar
so I went in to the gm dealership that my uncle works at, and the code that it gave was CO310, and its description was "motor circuit A/B open" the tech said that it is a problem in the wiring harness(like a short) or the transfer case control mod. is poopy. and thats where im at atm
Old Jan 24, 2012 | 03:21 PM
there ya go ya found your problem
you might wanna start looking at the harness by the encoder motor then the 4x4 module
Old Jan 26, 2012 | 06:43 PM
chaffinyo's Avatar
i narrowed it down to being the transfer case control, woot(kinda)
Old Jan 29, 2012 | 07:07 AM
sas10blazer's Avatar
sas10blazer is on a distinguished road
The tccm and encoder motors are problematic on these things.
Old Jan 29, 2012 | 07:33 AM
pettyfog's Avatar
ummm mine had several different TC problems showing up and 'binding while backing and turning'. I did a harness tug test and the light went out, started acting normally and hasnt come back. Knock wood.
Pull and clean all connectors then fresh silicone or dielectric grease in them.
Old Jan 30, 2012 | 08:09 AM
chaffinyo's Avatar
I did check the wirea and plugs, did a power test and all wires had power, uncle (GM tech) said that meant tccm. And it will be here today.
Does anybody know how hatch it would be to make 4wd, it would pry need the transfer case and tccm and the switch wiring harness?
:UPDATE: so its been a few weeks, and i bought a new "rebuilt" tccm and still no AWD any suggestions?
4goodbuys2
Lowering Tech
Dec 11, 2011 01:33 PM
pettyfog
Aug 30, 2011 10:19 AM
rednekk
Dec 22, 2010 10:00 AM
82 Iron Duke
18
Nov 17, 2009 09:36 AM
rednekk
Apr 17, 2008 09:09 PM
