2000 chevy blazer control arms
Old Aug 2, 2015 | 04:41 AM
Loweredblzr's Avatar
Loweredblzr is on a distinguished road
Default 2000 chevy blazer control arms
I'm new here, but I really really need help. I need some kind of a how to on replacing my upper and lower control arms. Any help would be greatly appreciated. Thanks in advance.
Old Aug 2, 2015 | 08:07 AM
LeWhite's Avatar
Do them one at a time! Uppers first as they are the easiest. The lowers require the shocks and sway links be removed and for safety a spring compressor applied. Watch your brake lines, that they dont get kinked. Also put the tires under the vehicle for double safety. You'll be fine. And post us some pics along the way!
Old Aug 2, 2015 | 10:32 AM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
Are we talking 2WD or 4WD?
Old Aug 2, 2015 | 02:00 PM
It is a 2nd drive. I almost need like a step by step to get these damn things off. I don't wanna mess anything up.
Old Aug 2, 2015 | 03:04 PM
LeWhite's Avatar
Lets do the top first. With the wheel safely under the frame. Remove the cotter pin for the upper bj stud. Loosten the nut until it is even with the end of the stud. Spray some penetrating oil under the nut between the upright. You will need a ball joint seperator ( not a pickle fork if you intend to use the old BJ). Press this between the upper and lower BJ stud. If expanding the BJ press doesnt loosten the upper BJ stud wack the spindle upright perpendicular and near to the BJ stud with a BFH. If still stuck a little heat from a MAP torch and more force will move it.
My battery is dieing I'll post later.
Old Aug 2, 2015 | 04:40 PM
I'm just doing the full control arm replacement. Fronts were easily done. Now I need help with the bottom lol
litterbox99
Jul 19, 2014 07:31 AM
002blazerdude
Lifting Tech
Oct 27, 2010 09:43 AM
greene
Apr 11, 2010 06:38 PM
grimreper912003
Dec 29, 2009 10:28 PM
Yooper
Jul 26, 2009 03:01 PM
