2000 Chevy Blazer Service 4wd Light on but no indicator lights on 4wd switch
Old May 27, 2020 | 04:20 PM
CaptJosh Moody's Avatar
CaptJosh Moody is on a distinguished road
Default 2000 Chevy Blazer Service 4wd Light on but no indicator lights on 4wd switch
Hi. This is the second time this has happened. I had a service 4wd light pop up on dash and the indicator lights on the switch will not come on. The briefly light up when starting the vehicle but that is it. I replaced the 4wd switch and still the same result. Checked the fuses . Nothing there either. replaced the atc fuse also. Nothing. The last time this happened i simply unplugged the 4wd switch and plugged it back in and it worked fine for over a month after that. But this time nothing. Cannot get a code for it either. I read somewhere that if yo pill the #8 fuse while the engine is running and replace it 30 seconds later this will reset it but there is nothing labeling the #8 fuse under the dash. Any help would be greatly appreciated as I use the 4wd on a regular basis.
boydsmith1961
Jan 19, 2019 10:28 AM
tom smith
Sep 25, 2013 11:09 AM
Grenkepr
Jan 17, 2011 08:57 AM
champ186dc
Jan 9, 2010 10:34 AM
aspenrebel
Dec 12, 2007 05:52 PM
