2000 Envoy Air Ride
Hi. I'm new here and my kid just picked up a 2000 Jimmy- Envoy edition with the air ride suspension. The air compressor runs every time the truck is started. The right rear corner sags when parked. Are there seperate air bags for each corner, or are there air shocks. I'm kinda stumped and not really sure what im looking for.
Thanks
Thanks
Thanks
Thanks
Check the front and rear stabilizer bar mounts and links. check the simple stuff, tires all inflated properly and same size, brand and model. Similar wear on all 4.
Could even be something complicated, like a weak spring or torsion bar. Could have the alignment checked.
Thanks, I'll check. I think it might be a bad rear shock. The compressor runs for several minutes before shutting off. I'm assuming each shock is filled indepently. If its a bad shock, can i replace with any air shock of the right size? Or is it a specialty item?
The easiest way to check is to start vehicle, close all doors, then add weight to the rear to make it lower, if the compressor starts and raises it back up then stops and it stays without the compressor running again right away, it is not leaking. Then if you remove the weight and the truck lowers after a about minute, the whole system checks out.
Like "swartlkk" says they are sold in pairs (if one leaks, the other will soon). And they are specific to the vehicle. Multiple shock manufacturers should make replacements.
Whether your air system is working or not, the lean is not a fault in the Air Ride System.
I have the same exact vehicle, but i did remove the air ride portion and keep the air to the rear cargo area to aid in filling tires or other items
with air, i installed the gabriel shocks for the jimmy and was able to lift it
also... but yea the shocks are availible from other companies, and a bit more pricy than standard shocks.
Robert
Robert
okiedoak20
Jan 10, 2010 08:51 PM
