2000 Jimmy - pass-side front axle seal....
Old Apr 28, 2010 | 08:04 AM
dougg01's Avatar
dougg01 is on a distinguished road
Default 2000 Jimmy - pass-side front axle seal....
When I rebuilt the front end on my Jimmy I also replaced both CV axles. I checked the axle seals before putting them in and both looked okay. The passenger-side seal is now leaking like crazy.
How hard is this seal to change...?
I'll probably try to get by with just disconnecting one of the ball joints to get the axle out (yes, removing brakes, hub, etc first). I can't leave it like this because it's leaking pretty good and to add fluid the skid plate has to come off.
Old Apr 28, 2010 | 08:38 AM
Once you get the CV shaft out of there, the seal is quite easy to replace. Just pry out the old seal and tap in the new. You have to make sure that you get it started square, but it shouldn't go in all that difficult.
You will just want to make sure that there isn't a groove worn into the CV shaft. If there is, then the new seal may not last as long as you would like. If there is a groove... You either reinstall it and hope for the best, or get a new CV shaft. The other alternative is finding a machine shop that can recondition the sealing surface either by spray welding and machining it back off or by machining it down and installing a sleeve, then remachining to size.
okiedoak20
14
Feb 3, 2014 08:23 PM
iamchevyman5
32
Dec 20, 2012 11:20 AM
Tony H
Jun 14, 2009 10:32 AM
toaks
Jul 25, 2008 12:03 AM
1989blazed
Mar 26, 2008 06:00 AM
