2001 4x4 broke axles and locked up
Old Feb 26, 2009 | 10:56 PM
nygneonkurtis's Avatar
nygneonkurtis is an unknown quantity at this point
Default RE: 2001 4x4 broke axles and locked up
might not be friday that i pull it apart because i have to go pick up a rollback a couple states away, but i will definitely take pictures when i do.
Old Mar 7, 2009 | 09:51 PM
Talking not front diff
so i tore it all apart on friday and im sorry to disappoint you but the differential was fine. got it completely changed and relized the axle was still locked up. got to messin around and figured out if the a arms are completely extended down, then the axles bind up and eventually snap. i have come to the conclusion that because it was an ex government vehicle, it is built with different tortion bars and other suspension odds and ends. because i got it stuck on the frame the a arms extended down and broke both axles. mleh, it was a good day of learning.
Old Mar 8, 2009 | 01:27 PM
I have never seen A-arms being all the way extended bind up the front axles... Do you have a lift on it?
Old Mar 8, 2009 | 05:43 PM
no, there is no lift on it what so ever. normal size 235,75,15 tires. its 100% stock other than the stereo. but yea, when put on jack stands, the front axles bind. you can turn them, but it was really hard. had to use a large pry bar between the studs.
Old Mar 8, 2009 | 07:35 PM
That is not normal at all... I had my old Bravada up on jackstands many times and been able to turn the wheels. Heck, I ran it in drive on jackstands for a bit to try to find the source of a noise I was trying to fix.
Twip
Jan 30, 2013 10:17 AM
chevy lady
Oct 23, 2011 07:34 PM
southpaw
Aug 4, 2010 04:45 PM
BLAZED821
Feb 2, 2008 09:13 PM
webbyj883
Suspension Tech
Sep 9, 2005 02:15 PM
