2001 caster/camber how to
Old Jan 20, 2023 | 03:09 PM
kagaminerin21's Avatar
kagaminerin21 is on a distinguished road
Default 2001 caster/camber how to
I just got done doing some work and my alignment is off by a bit and I'm wondering how to adjust the caster camber so I can take it for a proper alignment. Toe is good I have a gauge for the adjustment just don't know what to adjust.
Old Jan 26, 2023 | 12:14 PM
Jeff Fro's Avatar
Jeff Fro is on a distinguished road
might be a bit late to the party, but....Depending on how far you have to go to get it aligned or how far it's out, might not be worth messing with. The caster and camber are adjusted where the upper control arm is bolted to the frame. There are eccentric washers that are turned by turning the bolt head which will either bring the control arm in or push it out. Thus adjusting the caster/camber.
Hope this helps.
iceblue068
Aug 10, 2018 05:05 PM
95blazerlt
Mar 8, 2014 05:40 PM
Auflyer
Sep 28, 2009 05:18 PM
2001BlazrLS
Jul 16, 2009 02:24 PM
mick.p.
Jul 3, 2009 04:23 PM
