2002 Blazer Noise in 2WD Gone in 4WD
Old Jul 30, 2009 | 02:03 PM
mr_dbc's Avatar
mr_dbc is an unknown quantity at this point
Default 2002 Blazer Noise in 2WD Gone in 4WD
Hello,
My 2002 Blazer 2 Door has a terrible noise only in 2WD. Sounds like it's coming from the front possibly right side. It's similiar to when we were kids and used to put a card between our spokes on our bikes. As soon as you put it in 4WD or 4 Low the noise is completely gone. I'm wanting to use this truck to go away this weekend so any help would be greatly appreciated. I should mention the noise only occurs on rotation of the Wheel/Axle as oppose to being still.
Thanks very much,
DBC
Old Jul 30, 2009 | 03:07 PM
oktain's Avatar
Does it sound like grinding gears? Something may not be dissengaging properly and if that's the case I wouldn't drive it while it's making that noise. You'll do more damage than good.
Someone else may have a definite answer for you, like Swartlkk if he's around.
Old Jul 30, 2009 | 09:28 PM
mr_dbc's Avatar
Not really, it's more like a really bassy continuous axle click. Again like a baseball card stuck in the spokes of a bike wheel.
Old Jul 31, 2009 | 08:21 AM
Your front axle is not disengaging. The likely cause is a stuck front axle engagement cable. Try lubricating it with some penetrating oil and working the cable back and forth.
Old Jul 31, 2009 | 10:05 PM
mr_dbc's Avatar
ok, next foolish question, where is this front axle engagement cable?
Old Jul 31, 2009 | 10:10 PM
mr_dbc's Avatar
Oh one more thing, would this sticky axle still be a possible problem if the light on my dash shows that I am in 2WD?
Old Jul 31, 2009 | 11:01 PM
Yes, it definitely could.
Follow the cable up from the passenger side of the front differential into the engine compartment. I think on this vintage of s-series truck, the cable runs up to the vacuum actuator that is located on the passenger side inner fender.
Old Aug 1, 2009 | 02:05 AM
mr_dbc's Avatar
ok will check that out and post back results
thanks!
Old Aug 1, 2009 | 12:43 PM
No problem! Let us know!
Old Sep 9, 2009 | 10:04 PM
mr_dbc's Avatar
I thought the problem corrected itself as all of sudden all the noise was gone! However when I try putting it back in 4x4 the light on the dash just blinks and I hear a clicking under the glove box but it remains in 2WD. Could this still be the engagement cable?
Thanks,
DBC
