2004 blazer shaft removal{stuck}
Old Mar 31, 2019 | 09:13 PM
Craig Gaydos's Avatar
Craig Gaydos is on a distinguished road
Default 2004 blazer shaft removal{stuck}
after having fun with spark plugs and removing shaft from gear box i am unable to remove shaft so i can replace steering coupler that got damaged from misalignment after opening it slightly.Now i need to remove but i cant get more than an inch of travel out of it even after checking all forums and seeing that should slide ,,,,but it won't.................any hints????need help
Old Mar 31, 2019 | 09:45 PM
cleburne red's Avatar
Get a hammer and gently drive it toward the front of the truck. Mine was pretty hard to slide also. Just decades of dirt and grime holding it in place
Old Apr 2, 2019 | 08:47 AM
eshaw's Avatar
Yep what Cleburne said. When I took mine off I put a big set of vice grips on it and gently tapped it towards the front of the truck to get it off.
rrmagg06
Sep 13, 2020 08:36 PM
fishface
Sep 30, 2017 04:48 PM
kpzrx
May 28, 2010 12:04 PM
S10BEAST
Dec 6, 2009 05:36 PM
Bigjoey71
Suspension Tech
Jan 3, 2006 12:28 AM
