2005 Blazer with 4x4 problems
Old Dec 11, 2008 | 07:19 PM
dump_guy's Avatar
dump_guy is an unknown quantity at this point
Default 2005 Blazer with 4x4 problems
OK... the condensed version. Vehicle won't shift into 4hi. If I stop the vehicle & put into neutral, I hit 4hi, it'll flash 4hi & 4lo simultaneously then go back into 2hi. But lo & behold... Today I put it in neutral, pushed 4hi & lo together a couple of times & it went into 4lo. But it will not shift back to 4hi. Only back to 2hi... What the )^*(*) ??
Old Dec 12, 2008 | 03:26 PM
dump_guy's Avatar
Default RE: 2005 Blazer with 4x4 problems
If anyone else has this problem... The cheapest fis & first thing to try is... are you ready???
Disconnect the battery, leave it for a minute... (not sure how important it is to leave it for a minute but...) then re-connect it. WORKED LIKE A CHARM!!!
Thx to Byte Stryke for suggesting to post. I got snoopy & searched through other similar problems & came up with this fix.
Old Dec 12, 2008 | 06:24 PM
This is the typical sign for an encoder fault. The encoder is attached to the end of the shift motor on the side of the transfer case and is what tells the TCCM the precise location of the shift motor for proper model selection in the transfer case.
Do you have the Auto4wd option?
jasondis
Dec 30, 2012 10:40 PM
pardyryan
Nov 29, 2011 08:27 PM
RickBlazer
Jun 23, 2011 04:59 AM
watsoncb
Dec 19, 2010 03:01 PM
jan-jan
Feb 23, 2010 08:13 PM
