Are 2wd and 4wd rear ends the same
Old Sep 19, 2008 | 02:09 AM
Bad Ramer Jamer's Avatar
Bad Ramer Jamer is an unknown quantity at this point
Default Are 2wd and 4wd rear ends the same
My front seal is leaking pretty bad. I found a 2wd rear out of a 04 Extreme Blazer. Will it work on my 95 4x4. I wouldnt mine the rear disc brakes. Are they the same length.
Old Sep 19, 2008 | 06:26 AM
Default RE: Are 2wd and 4wd rear ends the same
No, the 2wd rear is narrower.
Why not just replace the seal?? Remove the driveshaft. Mark the position of the nut on the pinion and note the number of exposed threads. Remove the nut. Remove the pinion yoke. Remove the old seal. Install the new seal. Install the pinion yoke. Install the nut, tightening it down until the number of threads is correct and the alignment marks line up.
Old Sep 19, 2008 | 08:01 AM
Duh. For some reason I always thought you had to take the rear apart to change the seal. Good thing we have this new fangled thing called the internet. Thanks Kyle.
Old Sep 19, 2008 | 08:05 AM
For the axle seals, you have to remove the axles, but for the pinion seal, you just remove the yoke.
bowtie-72
Dec 30, 2013 04:56 PM
mikepro
Aug 15, 2011 07:03 PM
AmberRose
Aug 30, 2010 08:58 PM
Jason Rebellion
Jun 29, 2010 01:31 AM
