35mm sway bar?
Old Sep 8, 2014 | 10:48 AM
jpimp's Avatar
jpimp is on a distinguished road
Default 35mm sway bar?
I need a new front sway bar because the link hole is egg shaped on my 99.
I went to the junkyard this weekend and grabbed one off a 2002 blazer.
Got home...measured it for new bushings...
It is 35mm (34.9 with digital caliper)
so it is 1.375" \ 1 3/8" \ 35mm
problem is on Rockauto, the biggest sway bar on a blazer seems to be 33mm\1 5/16"
any one run in to this before?
any one know what bushing to frame to get?
Thanks!
Old Sep 8, 2014 | 05:25 PM
rexazz2's Avatar
I have seen multiple diameter listed for the same vehicle
check the year it came off of to see if they list different sizes , part numbers
Not sure if the strap mount is different or just the bushing
Old Sep 8, 2014 | 06:32 PM
jpimp's Avatar
Thanks for the reply rexazz2
I have the straps and bushings from the junkyard one. Bushings are bulged and oil soaked.
I can't figure out were to get bushings for this sway bar though. I checked the year it came out of. Rockauto doesn't list bushings this big.
Old Sep 8, 2014 | 07:05 PM
rexazz2's Avatar
for what you might save on them , I would probably just buy them local
cant remember the last time I changed a set @ the frame , so dont remember how much the tighten down on the bar
here is a moog link with dimensions
Moog Suspension Parts - Universal Sway Bar Bushings
Old Sep 8, 2014 | 07:14 PM
rexazz2's Avatar
BTW
they list 1 5/16 on the RWD in 2002
Old Sep 8, 2014 | 08:28 PM
jpimp's Avatar
Thanks bud
Old Sep 16, 2014 | 10:32 AM
jpimp's Avatar
Ended up not being able to use it.
Thread can be closed.
Thanks
pj5454302
Lifting Tech
Jan 21, 2010 08:19 AM
jaybird33081
Jan 4, 2010 03:12 AM
powwowblazer
Suspension Tech
Jun 26, 2006 05:22 PM
cherryred4x4
Suspension Tech
Apr 4, 2006 08:05 PM
timetoblaze
Suspension Tech
Oct 30, 2005 12:17 PM
