4 wheel drive 99 ls 2door
Old Nov 27, 2013 | 03:12 PM
BLAZERK's Avatar
BLAZERK is on a distinguished road
Default 4 wheel drive 99 ls 2door
So ive got a 99 ls 2dr 4x4, i purchased the truck a few months back. I was told the 4 wheel drive didnt work but i never tryed to engage it. Winters coming pretty quick and im considering trying to fix it. Its not throwing any codes.
Also had a few other questions on the vehicle.
After my truck has ran for a while when i stop at lights with the it in drive the rpm's seem to periodicly raise and then drop, with it in park it does not do it.
When i turn the car in and listen near the rear drivers side tire i can hear hissing, again not throwing any codes.
Also wondering if they make fender flares specific to my blazer, and what size tire i could stuff under it with minimal to no rubbing.
Old Nov 27, 2013 | 03:24 PM
jpimp's Avatar
jpimp is on a distinguished road
https://blazerforum.com/forum/tech-a...ill-help-7180/
post # 5 really good info
for rpm at stop light, have you done a tune up? Delco plugs?
I think the tires can't really go much bigger without a lift or spacers
Old Nov 27, 2013 | 03:50 PM
Diaita's Avatar
A/C compressor turning on and off can make the idle fluctuate a little.
Is it a hiss you are hearing, or the faint whine of the fuel pump? The fuel tank is right where you're listening. Vacuum leak perhaps?
Old Nov 27, 2013 | 04:35 PM
BLAZERK's Avatar
I havent done a tune up yet i plan on doing wires plugs and fluids very soon.
The top far right pully has like a disc on te end and sometimes itll all spin and then others jus the pully and not the plate.
And it is a hiss
Old Nov 27, 2013 | 04:48 PM
jpimp's Avatar
make sure to do cap and rotor with the tune up, and pcv valve doesn't hurt...and fuel filter since were talking driveablity
that disc is the A\C compressor kicking in and out
Old Nov 27, 2013 | 05:21 PM
newguy's Avatar
sounds like a vacuum leak
mirrorimij
Jun 8, 2019 03:34 PM
lizzj70
Jun 23, 2010 06:57 PM
deegan26
Apr 5, 2010 11:20 PM
bear
Jan 5, 2010 02:51 PM
steeltoe
Suspension Tech
Jun 15, 2005 05:40 PM
