4wd to 2wd
Old Dec 6, 2008 | 05:48 PM
willum98e's Avatar
willum98e is an unknown quantity at this point
Default 4wd to 2wd
when I switch from 4wd high to 2wd, I get a loping tire sound at about 25mph. if I switch back and forth 2wd-4wd it eventually goes away. any ideas? light indicators look normal. I can hear a click when I switch. new tires changed nothing.
this is a 2004 2 dr, 3 button 4wd blazer with about 50,000 miles.I thinkthat 4wd both hi and low work fine.
Old Jan 1, 2009 | 10:06 PM
ChevyBoy413's Avatar
ChevyBoy413 is an unknown quantity at this point
Default RE: 4wd to 2wd
you should be parked when you engage and disengage the 4WD and make sure all 4 tires are the same in size and tread
swartlkk
Feb 6, 2025 09:57 PM
theclothedcreature
Lifting Tech
Jan 22, 2010 01:37 PM
jack
Aug 5, 2006 10:59 AM
fenderfree
Dec 14, 2005 09:04 PM
zero psi
Tires and Wheels
Apr 22, 2005 11:54 PM
