4WD and Clutch Issues
Old Jan 8, 2012 | 08:01 PM
dgreak's Avatar
dgreak is on a distinguished road
Default 4WD and Clutch Issues
Hey guys not sure if the clutch question goes here, but hopefully I can kill 2 birds with one stone. I have an 86 S10 4wd blazer, and my 4wd is not working. When I put it in 4wd you can feel the transfer case engage, but the front tires, or tire, does not pull. I have a bearing that needs to be replaced in the drivers side front hub, is that the 4wd assembly? I think this vehicle only has one tire that pulls in the front, and one that engages in the rear?
Now my clutch issue...my clutch seems to be working, but when I press the clutch in it sometimes make a loud popping noise, and has no resistance. I can pump it a few times and it will work fine. Any thoughts on that one?
Thanks in advance for your help.
Old Jan 15, 2012 | 12:34 AM
jaked up's Avatar
jaked up is on a distinguished road
you have open diffs frount and rear and as far as your 4wd if i recal rightly you should have auto locking hubs which suck bc if one hub stops working then no more 4wd so the reason your 4wd is not working is in your frount end somewhere
road1420
Aug 9, 2015 10:48 PM
austrochevy
Aug 8, 2013 09:04 AM
MintyMadness
Jul 13, 2011 12:37 AM
Red03
Sep 25, 2008 08:37 PM
brightonwingman
Jul 20, 2008 12:29 AM
