4wd not working.
Old Jan 21, 2009 | 03:50 PM
Logan's Avatar
Logan is on a distinguished road
Default 4wd not working.
2002 Jimmy with the 3 button 4X4
Ok...ive been reading everything I could find on this, and im stumped!
No lights flash the the ignition is on. The lights on the dash work fine, I put it in 4x4hi light goes there and stays on. I hear the click from the passenger side, and the t-case clicking into 4hi. But the front wheels dont spin. pulled the hose off the actuator, and it seems to move. Now there seems to be a constant vacuum on it. I dont usedrstand what else could be wrong.
Here is the hoses thats under the hood. I traced them back as best as I could. The one I labelled that goes to the actuator, goes behind the engine but when i pulled on it, the hose to the actuator moved.
Old Jan 21, 2009 | 05:27 PM
Logan's Avatar
Default RE: 4wd not working.
Ok...managed to find out where the vacuum hose goes that I listed to actuator. Im going to replace the t-case vacuum switch and see what happens.
Old Jan 22, 2009 | 02:35 PM
Logan's Avatar
ok... I replaced the T-case vacuum switch. The ball was stuck on the old one.... But now it will only go into 4wd when the rear wheels are spinning and I push 4wd. There is a little grind then it goes into 4wd. No matter what else I do it wont go into 4wd. and still no codes regarding 4wd. Should I replace the actuator, or does anyone think its the motors going???
Old Jan 26, 2009 | 10:03 PM
user 1016's Avatar
user 1016 has a spectacular aura aboutuser 1016 has a spectacular aura about
Does it go into 4 low?
Old Jan 27, 2009 | 08:44 AM
Where do you hear the grinding coming from? The front end (front axle engagement) or under you (transfer case)?
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
mjw1991
Feb 24, 2013 10:18 PM
218persuader
Aug 20, 2010 06:11 PM
chrisblaze
Dec 6, 2009 12:27 AM
LYK2ROC
Dec 5, 2008 07:08 PM
