4WD problem
I assume you mean 2001.
The transfer cases used in the s-series trucks are all shift on the fly capable meaning that you can shift from 2HI to 4HI while driving. It does make the transition a lot easier when the truck is coasting and/or at relatively low speeds, but it is not necessary to stop or have the transmission in neutral to make the shift.
What happened when you tried to put it into 4wd? I cannot see any reason why a shift to 4HI would cause the truck to not go into reverse. Please detail your situation more thoroughly and we'll try to help as best we can.
waterskier98
Mar 4, 2009 03:15 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
