4WD problem
Old Feb 17, 2014 | 07:58 AM
BatesBlazer's Avatar
BatesBlazer is on a distinguished road
Default 4WD problem
I tried to put my 2011 Chevy Blazer in 4WD while in drive. When I realized my mistake I put it in Neutral, but then I couldn't put it in reverse. Did I do long-term damage?
Old Feb 17, 2014 | 08:04 AM
I assume you mean 2001.
The transfer cases used in the s-series trucks are all shift on the fly capable meaning that you can shift from 2HI to 4HI while driving. It does make the transition a lot easier when the truck is coasting and/or at relatively low speeds, but it is not necessary to stop or have the transmission in neutral to make the shift.
What happened when you tried to put it into 4wd? I cannot see any reason why a shift to 4HI would cause the truck to not go into reverse. Please detail your situation more thoroughly and we'll try to help as best we can.
2001 ZR2
Jan 16, 2010 12:39 PM
LJ809
Nov 25, 2009 08:43 AM
waterskier98
Mar 4, 2009 03:15 PM
aspenrebel
Dec 12, 2007 05:52 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
