4wheel low light blinking on 95 blazer
Old Feb 21, 2007 | 12:48 PM
allforenot's Avatar
allforenot is an unknown quantity at this point
Default 4wheel low light blinking on 95 blazer
hi guys i just bought a 95 blazer... when i push the 4 wheel low button it blinks and the 4 wheel hight button lites as well... is this normoal or is there a problem with the 4 wheel drive? thanks
Old Feb 21, 2007 | 12:53 PM
Default RE: 4wheel low light blinking on 95 blazer
Please check the DIY post on OBD2 Non-Automatic Transfer Case Diagnostics
As with any of these types of problems, you should check over all grounds under the dash and underhood as well as pulling the connections off of the encoder motor on the transfercase and the transfercase control module (located behind the front kick panel on the passenger side) and check for corrosion.
Old Feb 21, 2007 | 02:00 PM
eshballa5's Avatar
eshballa5 is an unknown quantity at this point
ive found that you need to put the truck in neutral and be going less than 3MPH and the light will stop blinking and switch over to 4lo. of course you need to do the same thing to get it out of 4lo
Old Feb 21, 2007 | 02:55 PM
allforenot's Avatar
thats a neat trick... going to see if it works on mine
Old Feb 21, 2007 | 05:50 PM
LT1KICKER's Avatar
LT1KICKER is an unknown quantity at this point
Here's a problem: My 2000 Blazer has been been in 4wd quite a bit lately. It has the Auto 4wd option, 2Hi, 4Hi, and 4Lo options. We've been using all of the above with the large amount of snow here. Well, today, when it was placed in Auto 4wd to go thru some nasty streets, it suddenly will not release from this mode. Instead of going back to 2hi when pressing the Auto button again, it tries to put the truck in 4Lo! Help.
Old Feb 22, 2007 | 12:04 AM
pvollman's Avatar
pvollman is an unknown quantity at this point
Check your switch could be bad...that is a good place to start. Then the actuator.
navarro913
Sep 12, 2010 08:07 PM
haha29
Feb 10, 2010 05:53 PM
myinkfreak
Oct 18, 2009 07:41 AM
diceman721
Oct 2, 2009 07:22 PM
bir11
Jun 6, 2009 04:05 AM
