4x4 Engaging, No Front Wheel spin 4hi/4lo
Old Jan 12, 2022 | 05:39 PM
BBlazer03's Avatar
BBlazer03 is on a distinguished road
Default 4x4 Engaging, No Front Wheel spin 4hi/4lo
My 4x4 used to work just fine last winter, however it started to make some strange sounds this winter. The sounds could be described as a low grinding mixed with humming you can feel throughout the cab. Now the blazer is engauging into 4hi/4lo but I do not have any power to the front wheels. 4lo also spins the rear at 4lo speeds.
Old Jan 12, 2022 | 06:55 PM
It sounds like the front axle is not being engaged. This could be due to the vacuum actuator that pulls on the cable to the front axle leaking, the vacuum line to the actuator leaking, the other vacuum lines connected to the engine are leaking, or that the gears in the axle that are engaged by the actuator are stripped.
At least in the second gen Blazers (what hear is yours?), a leak in the vacuum lines under the hood will also cause issues with HVAC system actuators under the dash in addition to the front axle not being engaged due to lack of vacuum. This is what happened to me. Fortunately, the fix of replacing all the vacuum lines is not too hard to do.
Old Jan 12, 2022 | 07:07 PM
BBlazer03's Avatar
its a 2003 Zr2 on 33's Is the vacuum actuator the little diaphragm contraption under the battery?
Old Jan 12, 2022 | 09:14 PM
Yep, the actuator under the battery tray pulls on a cable to engage the axle.
What you can do is see if it moves when you select 4wd. If not, there is a vacuum leak. You also can trace the hose to it to where you can disconnect it and apply a vacuum separately.
Is your transfer case control have three buttons or four with the auto 4wd setting?
I have a link in my signature for checking and replacing the underhood vacuum hoses.
Old Jan 13, 2022 | 12:52 AM
BBlazer03's Avatar
4 button Auto/2hi/4hi/4lo
thanks!
Old Jan 24, 2022 | 04:02 PM
BBlazer03's Avatar
Hey there, So i replaced the 4x4 Diaphragm Cable Contraption and still no result. its pulling and holding a vacuum I watched the actuator suck in/out going from 2hi/4hi. Anything else to check on?
Old Jan 24, 2022 | 04:45 PM
I have never tried this but you should be able to engage the front axle by manually pulling on the cable that goes between the vacuum actuator and the front axle.
If you cannot engage the front axle by doing that, then my best guess is that either the cable is broken, its attachment to the axle mechanism is broken, or the gear(s) of the axle engagement mechanism are stripped.
Do you have any exploded diagrams or a repair manual to help you?
Old Jan 24, 2022 | 04:46 PM
BBlazer03's Avatar
Nope im going in blind to this whole thing. Ill check the cable
Old Jan 24, 2022 | 04:49 PM
BBlazer03's Avatar
I dont know if this is working correctly might be
Lil_J_357
Aug 23, 2013 08:24 AM
614blazer
Dec 19, 2011 02:31 PM
biniecki
Feb 21, 2011 07:18 PM
texter
Jan 9, 2011 07:55 PM
EvilPotato
Oct 1, 2007 07:32 PM
