4x4 help please!
Old Feb 28, 2008 | 04:48 PM
fst450's Avatar
fst450 is an unknown quantity at this point
Default 4x4 help please!
when i put my truck in 4x4 hi or low and accelerate it sounds like the front right wheel or maybe both front wheels arnt engaging and slippingout with a crunch noise. depending on how hard i push it it slips more. any help would be great thanks!![:@]
Old Feb 28, 2008 | 07:51 PM
WolfPack's Avatar
Default RE: 4x4 help please!
If you're feeling a gringing/cruching you're front wheels are definitely engaged, and youre actually grinding your transfer case. On these trucks the 4wd is only meant for conditions in which your wheels can slip freely.. i.e. not on pavement.
If you keep pushing the truck through turns or if you keep driving in a straight line (like on a highway), you'll eventually build up enough axle wrap to crack open your T-case..[:@]
Remember: 2Hi till you get stuck
Old Feb 29, 2008 | 05:08 PM
fst450's Avatar
i went and checked it out but its not the transfer case its clearly clunking from around the front axel passenger side it makes the same noise when i flick it to two wheel drive accelerate and the front wheels unlock it makes a bit of a clunk. It doesnt do it all the time just some times.
Old Feb 29, 2008 | 06:05 PM
94blueknight's Avatar
94blueknight is on a distinguished road
ORIGINAL: fst450
possibly something in the front differential is bad
Old Mar 4, 2008 | 08:27 PM
fst450's Avatar
has anyone ever had a hub slipping on the spline on a front axle??
Old Mar 5, 2008 | 11:42 AM
WolfPack's Avatar
Yea I had a driveline clunk and thought it was the tranny...but I did a rear axle service, and apparently it was the rear diff, cause the clunk is now gone!
You probably ground a tooth off or something wild up in the front differential when the axles bound up real hard. I'd have it checked out soon, and not use 4x4 till you do!
Old Mar 5, 2008 | 07:17 PM
fst450's Avatar
thanks!
opposedforces
Sep 1, 2011 02:59 PM
mikejoann
Jan 4, 2010 10:23 AM
rogggg1020
Nov 11, 2008 08:05 AM
scoot
Jan 1, 2007 04:48 AM
1996blazer
Dec 6, 2006 09:34 PM
