4x4 not engaging
Old Jan 17, 2010 | 03:47 PM
95 S10 Blazer's Avatar
95 S10 Blazer is on a distinguished road
Default 4x4 not engaging
i have a 95 blazer and ive gotten stuck 3 times because my 4x4 dosent work. today me and my mechanic tried to pinpoint the problem. when i put it in 4lo i can hear the transfer case engage. the vac diafram looks to be working. and when its in 4wd the front driveshaft going from the tcase to the front diff is locked. but my front tired dont spin. so its something in the front end right? if anyone can help that would be fantastic.
Old Jan 17, 2010 | 03:51 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
sounds like your front diff isn't working right if your driveshaft from it to the t-case is spinning.
Old Jan 17, 2010 | 03:59 PM
Very common problem and covered in many other threads. If the actuator is not pulling the cable 1/2" to 3/4", it is not pulling it far enough. This is either due to a frozen cable or a problem with the vacuum system to the front actuator not supplying enough vacuum. If it is pulling the cable that far, then the problem lies deeper into the front axle engagement mechanism inside the passenger side extension tube.
Old Jan 26, 2010 | 03:21 PM
bstocksblazer's Avatar
bstocksblazer is on a distinguished road
Default More vac issues
So if your vac actuator isnt working but is in good shape, and you are not gettting vacuum to it ( crank engine, engage and feel no vacuum pull on hose), where is the next place to look? I have read that there is a vacuum aparatus above the transmission but that sounds like a pain to get to. Does anyone have any ideas for installing a manual engage cable? (sorta like an old choke cable mounted inside the cab somewhere)
There was no evidence of fluid in the vac hose and my tranfer case does engage the driveshaft to the front axle.
Old Jan 26, 2010 | 05:50 PM
Banned
there is a way to make a manual cable. its in the how to section, i'll see if i can find it.
Old Jan 27, 2010 | 01:51 PM
you released the hounds spectre and I found it. There is a how-to here: https://blazerforum.com/forum/showth...ight=posi+lock
its a great write up. Thanks!
Old Jan 27, 2010 | 04:42 PM
Banned
yup. no problem
seriosbrad
Nov 7, 2015 09:08 PM
chrisblaze
Dec 6, 2009 12:27 AM
TheBrettster
Mar 31, 2007 07:24 AM
Jared
Sep 15, 2006 12:52 AM
I8URVTEC
Jul 28, 2005 06:56 PM
