4x4 not working
Old Mar 2, 2009 | 01:03 PM
FlatTopFoley's Avatar
FlatTopFoley has a little shameless behavior in the past
Default 4x4 not working
So we had about a foot of snow today and wanted to test out the 4x4 (havent had a chance to try it out yet) So me and another fourm member (86Blazer4x4) head up to a school, put it in 4 hi and do some drifting. He does a few good ones then I get behind the wheel and do one and get somewhat stuck. Go to get out and only the back tires are spining, the fronts are just sitting there, relaxing, being lazy. But anyway, on the 4x4 selector is working fine but its just not shifting in. Any ideas on what to check? Also heres a video of me getting stuck
http://www.youtube.com/watch?v=3j5A6Y4Pmcw
Old Mar 2, 2009 | 01:21 PM
bammontana's Avatar
bammontana has a little shameless behavior in the past
Default RE: 4x4 not working
Check to make sure the actuator cable is not frozen,
checking to make the actuator is not broken,
check the vaccum is holding from the switch on the transfer case,
make sure all your vac lines are hooked up,
if everything else is fine then your vac switch on the transfer case might of failed. when you do the selector do you hear a click noise from the passenger kick panel?
Old Mar 2, 2009 | 05:24 PM
got it. The vac line wasn't plugged in and it had huge cut on it, barley held together. replaced the line, everything working fine now. thanks!
Old Mar 2, 2009 | 05:44 PM
bammontana's Avatar
Great, glad to hear.
Old Mar 2, 2009 | 08:24 PM
RWRIGHT's Avatar
RWRIGHT is an unknown quantity at this point
flattop??? how did you this out..... Status: Running at 89% operational capacity
Old Mar 2, 2009 | 10:06 PM
86Blazer4x4's Avatar
86Blazer4x4 is an unknown quantity at this point
we tested it out by taking it through the snow. or are you talking about the 89% operational capacity?
Old Mar 3, 2009 | 07:31 PM
Must just mean that there are other gremlins to work out...
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
mjw1991
Feb 24, 2013 10:18 PM
bootlegger
Dec 14, 2010 05:18 PM
218persuader
Aug 20, 2010 06:11 PM
