4x4 not working
RE: 4x4 not working
ORIGINAL: Chevy Lover
Do you get the contact "click" with the engine running and you push the button to engage the 4X4?
I'm still trying to figure out if you are getting vacuum to the cable actuator under the battery.
ORIGINAL: fred96
when i hear the contact this is with the motor off and the car in park
im using vice grips to engage the cablemanually myself
RE: 4x4 not working
bump
i really could use some more help i still havent been able to diagnose it yet
RE: 4x4 not working
bump
RE: 4x4 not working
fred, I don't know how you can diagnose it if it doesn't have a 4 wheels off the ground.
I would have it sitting on jackstands, engine running, 4X4 engaged and see if the vacuum actuator is pulling the engagement cable, or at least pull the cable as you have done, but with the engine running, trans in drive and transfer case engaged.
RE: 4x4 not working
RE: 4x4 not working
had same problem with my 99 blazer it turned out to be the gear in the front axle that was all ground up bougt new gear shift fork and spacer kitseems to work ok now but was a pain to do
[IMG]local://upfiles/9427/732184E697D94332B00250A2931F5F9D.gif[/IMG]
Jack up front end place jack stands underneath. Dissconnect 3 bolt housing, dissconnect shift cable,now MANUALLY pull out on fork shaft. If you spin one tire and other doesn't move shift collar not engaging. Most likely cause is bad thrust washer behind axel gear. Washer kit $10 from dealer. To repair you must remove shaft tube. Hope this helps.
mjw1991
02-24-2013 10:18 PM
blazer9893
06-07-2011 04:21 PM
bootlegger
12-14-2010 05:18 PM
218persuader
08-20-2010 06:11 PM
