4x4 only works on flat ground
i have a 93 s10 4.3 4x4 everything ingages and works properly as long as i amd on flat ground but as soon as one of my rear wheels looses traction im stuck all my power goes to that wheel and im stuck i have no front wheel spin unless my rears have traction .... any ideas ?? thanks
Not everything is engaging properly if you do not have power to the front axle at all times. When your transfer case locks into 4wd, the front and rear driveshafts are locked together. So you either have a problem in the transfer case or in the engagement of the front axle.
This. Throw a locker in the rear. Don't even think about adding one up front unless your ride is 95% used off road. Some research will let you know the differences in all the lockers out there along with the differences from a limited slip diff.
scrawford
Dec 29, 2009 05:51 AM
cide
May 1, 2009 01:07 PM
