4x4 only works on flat ground
Old Dec 23, 2010 | 01:40 PM
twisteds10blazer's Avatar
twisteds10blazer is on a distinguished road
Question 4x4 only works on flat ground
i have a 93 s10 4.3 4x4 everything ingages and works properly as long as i amd on flat ground but as soon as one of my rear wheels looses traction im stuck all my power goes to that wheel and im stuck i have no front wheel spin unless my rears have traction .... any ideas ?? thanks
Old Dec 23, 2010 | 01:43 PM
Not everything is engaging properly if you do not have power to the front axle at all times. When your transfer case locks into 4wd, the front and rear driveshafts are locked together. So you either have a problem in the transfer case or in the engagement of the front axle.
Old Dec 30, 2011 | 08:39 PM
OK got the front wheel drive situated and working but now in sticky situations I only get one front one rear ... fixes both expensive and cheap??
Old Dec 30, 2011 | 08:49 PM
j89lumaye's Avatar
j89lumaye is on a distinguished road
You dont have a locker or limited slips in the axles, you get one wheel, which is the wheel with the least amount of traction
Old Dec 30, 2011 | 09:22 PM
AJBert's Avatar
This. Throw a locker in the rear. Don't even think about adding one up front unless your ride is 95% used off road. Some research will let you know the differences in all the lockers out there along with the differences from a limited slip diff.
eljorgin
May 21, 2019 10:04 PM
scrawford
Dec 29, 2009 05:51 AM
cide
May 1, 2009 01:07 PM
peanutblaze
Feb 11, 2008 09:15 AM
rxvette
May 6, 2006 12:24 AM
