4x4 problem!
Old Oct 17, 2007 | 11:17 PM
yazan84's Avatar
yazan84 is an unknown quantity at this point
Default 4x4 problem!
Here's the deal I drive 1999 blazer 4x4 and I noticed last winter that whenever I transfer to Hi4 mode and turn the wheels the tires vibrate and turns rough. Couple months ago I hit the Hi4 button &it took awhile to transfer from regular mode. Nowlast week I've tried to transfer to Hi4 and it's not working at all.
What should I do? SNOW IS ON THE WAY!!
Old Oct 18, 2007 | 06:05 AM
Default RE: 4x4 problem!
The chattering turn while in either 4hi or 4lo is perfectly normal. Now the slow transfer is not normal, but is pretty common. Does your light just blink then switch back to 2hi? If so, then the TCCM is sensing a fault in the engagement of 4hi and not transferring in. Do you have Auto4wd? If not, then check out the DIY section for the OBD2 Non-Automatic Transfer Case Diagnosis.
Hope this helps!
Old Oct 20, 2007 | 10:43 AM
yazan84's Avatar
I have Auto 4wd. It used to flash before for awhile then turns on 4Hi, but now it's not even flashing!
Tinted
35
Feb 7, 2011 01:12 PM
English5
Jul 16, 2010 11:11 AM
razman
Feb 22, 2009 01:57 PM
sdm1234
Jan 2, 2008 12:12 AM
tolleyc
Jul 29, 2007 05:57 PM
