4X4 Problem
Old Feb 9, 2010 | 03:04 PM
thedenteraser's Avatar
thedenteraser is on a distinguished road
My 98 Blazer keeps blowing the ATC fuse when I try to switch out of 4hi or 4lo. I cleaned all the connections on the TCCM. What else could it be?
Old Feb 9, 2010 | 03:12 PM
mike mtzr2's Avatar
mike mtzr2 is on a distinguished road
if you have extended needle nose you can go in from the front by pulling the 2 headlight clips pull the lite forward let it hang use a flash-lite and pick a hole, be cautious of damaging your new rubber diaphragm. did you put your transfer case vacuum switch down as far as the original one?
Old Feb 9, 2010 | 09:15 PM
notrealimportant's Avatar
notrealimportant is on a distinguished road
just fyi I found a hole in the new actuator that I just bought on friday. Obviously that part is no good, so I'll take that back tomorrow and get another one and see whats going on there. As a side note, Ill add another T fitting in the mix and plug in the reserve ball and see what that does. I took the check valve out and put in a standard T fitting and now my heater control changes from defrost to floor etc...
Old Feb 9, 2010 | 09:17 PM
The check valve might have just been installed backwards. The check valve should be the first thing in that line, then it should T off into the HVAC, 4wd, and vacuum reservoir.
Tinted
35
Feb 7, 2011 01:12 PM
English5
Jul 16, 2010 11:11 AM
razman
Feb 22, 2009 01:57 PM
sdm1234
Jan 2, 2008 12:12 AM
tolleyc
Jul 29, 2007 05:57 PM
