4x4 problems
Old Feb 7, 2011 | 05:30 AM
94BlazerDazer's Avatar
94BlazerDazer is on a distinguished road
Default 4x4 problems
Hey I have a 1994 S10 Blazer and I am having some 4x4 problems and im not sure where to start looking.
I have the button to engage the 4x4 and its really aggravating. sometimes i cant get it out of 4x4, i have to play with it for a while.
and I can hear the transfer case engage but my front wheel will not spin.
idk where i should start and look.
Please help
Thanks
Old Feb 7, 2011 | 06:34 AM
You can start by having a look in the Tech Article (DIY) Index link in my signature. Lots of good info there!
This thread should be helpful:
Common 4x4 Problems
*Moving to Steering, Suspension, & Drivetrain*
Old Feb 7, 2011 | 11:28 PM
Jaymoung's Avatar
Jaymoung is on a distinguished road
i have a 1995 4dr 4x4 blazer and my front tires will not spin at all i looked at the link but i was wondering if this go with my 95 blazer also?
Old Feb 8, 2011 | 12:43 AM
burning_soul07's Avatar
burning_soul07 is on a distinguished road
Check the link in my sig about the vacuum. Should be about the exact same setup.
Old Feb 11, 2011 | 12:14 PM
gregl316's Avatar
gregl316 is on a distinguished road
Default front axil
all I can say is look at the vacuum diagram and don't over trouble shoot.
My front axil wasn't engaging either.
I checked tho vacuum to the engager diaphrem located under the battery and it was only get 4 inches. I checked the vacuum to the transfer case and it was at 15". So I figured it was the switch on the xfer case so I bought a new one at the tune of 47 dollars. That didn't work either . So scratching my head I checked the vacuum line that leads from the switch to the engager under the battery with a vacuum pump to find I couldn't draw any vacuum. The hose ran over the trans so I couldn't see it. I replaced it to find the hose had two holes rubbed in it. Now it works fine
So the moral of the story is check everything before you just throw money at it.
Old Feb 12, 2011 | 08:08 AM
Russell Mack's Avatar
Russell Mack is on a distinguished road
Default 99 trailblazer 4x4 wont engage
The control module on the kick panel under the dash engages,the acuater on the transfer case engages,but the electric switch on the dash still flashes and the 4x4 wont engage.Any ideas?
Old Feb 12, 2011 | 08:35 AM
Considering that you have a completely different setup (NV236 transfer case) as what is being discussed in this thread (NV233 transfer case), it is best if you create your own thread on the subject if you cannot find the information you need after searching and reading the threads in the Tech Article (DIY) section.
notrealimportant
Jul 15, 2011 01:29 PM
Aanenson
Apr 14, 2011 09:12 PM
upblazer95
Apr 4, 2009 08:27 PM
chevblazer02
Oct 15, 2006 03:03 PM
vtlew
Jun 23, 2006 09:13 PM
