4x4 Switch lights flickering.
Old Apr 9, 2013 | 09:06 PM
clbychil's Avatar
clbychil is on a distinguished road
Default 4x4 Switch lights flickering.
I have a 1999 with the three button dash switch.
Unlike most posts I've read about the switch lights blinking(which I have experienced), my lights are flickering wildly and are inconsistent. I believe its in 2wd most of the time but lately its been driving weird and jerking alot especially up hills and the flickering has become more and more apparent. Also, when I push the buttons nothing happens. I have recently changed the seals and vacuum switch and have looked at the actuator, all of it seems fine.
Any thoughts?
Old Apr 10, 2013 | 12:00 PM
clbychil's Avatar
Could it be the the control module or motor? And are there any ways to pinpoint it?
Old May 5, 2013 | 06:44 PM
clbychil's Avatar
Quit for a while and started again. I cleaned all the connections. The lights still either flicker or are all off.
Old May 5, 2013 | 08:31 PM
jasond's Avatar
jasond is an unknown quantity at this point
I had a similar issue with the lights, I replaced the switch with a Delco part I found on eBay. It solved my problem.
Old May 8, 2013 | 12:32 PM
mike3epo's Avatar
mike3epo is on a distinguished road
so if the lights are off and it wont engage the 4x4 what should be the first thing i look at?
i have an 01 zr2
Old May 8, 2013 | 07:32 PM
Kreigeist89's Avatar
Kreigeist89 is on a distinguished road
Check and clean the TCCM. Check the connections to the switch sounds like they are loose or you have a faulty connection.
RIFLEMAN 308
Nov 12, 2020 06:30 PM
Numba1Sean
17
Nov 16, 2008 06:59 PM
mikeinwi
Jun 14, 2008 08:12 PM
mikeinwi
May 11, 2008 07:41 PM
USMaverick101
Mar 28, 2007 07:55 AM
