4x4 works fine but...
Old Oct 12, 2009 | 04:53 PM
nickdouglas's Avatar
nickdouglas is on a distinguished road
Default 4x4 works fine but...
When i put my 97 blazer into four wheel drive you would think it was ok, it has the power and the lights and everything comes on correctly, but when i go to test it out the front tires will not engage. I can tell the transfer case has kicked in but can not get any movement to front tires. any anwsers, thank you.
Old Oct 12, 2009 | 07:21 PM
NVANZEE's Avatar
how are you testing this.
Old Oct 13, 2009 | 12:21 PM
I have tested it by power braking it on the pavement and by getting stuck on wet grass, lol. I have the power of 4lo but dont have the front tire movement
Old Oct 14, 2009 | 08:06 PM
Stitch17's Avatar
Stitch17 is on a distinguished road
Ya didn't take the front driveshaft out did ya =P lol
Old Oct 14, 2009 | 10:41 PM
ABN31B's Avatar
throw it up on jack stands, drop it in 4(hi or lo) and give her a bit of gas... fronts spinning?
Yes? --> you = win
No? --> you = sad
Old Oct 15, 2009 | 08:03 PM
Stitch17's Avatar
I don't think it'l engage 4Hi or 4Lo while the tires are off the ground. You'd have to set it to say 4Hi then put it up and try it.
Check for vacuum at the front drive axle clutch solenoid. It's on the left hand side of the engine bay, somewhere around 6-7 inches from the bottom of the left wiper arm, you will see a handful of air lines going into a couple T's. Take the one that goes down under the motor off and feel the hole where you took it out of (the one thats connected to the engine) and see if you have vacuum. If you've got no vacuum, chances are you've got a vacuum leak causing the front drive axle not to engage.
LilSki
Jan 12, 2015 06:04 PM
trail_blazer
Feb 10, 2013 02:52 AM
benp#38
Aug 17, 2011 03:17 PM
Kjared2
Jul 27, 2011 05:23 PM
jpimp
Nov 25, 2010 11:10 PM
