6 inch lift cheaper.
Old Feb 16, 2008 | 09:42 AM
ratical12001's Avatar
ratical12001 is an unknown quantity at this point
Default 6 inch lift cheaper.
Hey fellas, i was gonna buy a 6 inch lift to raise my blazer but 1800 bucks,no way. i just found a wrecked 99 jeep cherokee. axles are same width as mine. i am gonna remove all my blazer suspension and replace it with jeep. front axle off jeep also has cable actuated 4x4. am gonna use front coil spring. has any one else done this. i am a welder and machinest by trade . and this just my spare time. any one else done this. i want to run 33x12.50 /15 . gears for the jeep are about a 100 set, and a locker on ebay 100. so i figure for about 400 for the jeep wheels are 800 through summit. so i should have all i need for 1800. and gears i want and tires and rims to boot. any opinions
Old Feb 16, 2008 | 09:58 AM
YepIOwnA97Blazer's Avatar
YepIOwnA97Blazer is an unknown quantity at this point
Default RE: 6 inch lift cheaper.
go to s10forum liftin' it section, tim99zr2 did exactly what you want to do. SFA swap and made pretty much everything from scratch.
SFA link
Fixed long link. TBB
Old Feb 16, 2008 | 11:22 PM
wow . alot of info .. thank you. this is just what i want to do. perfect. thank you
Old Feb 17, 2008 | 06:58 AM
With a cursory look over that link, it provides a lot of good information, but one thing it leaves out is the proper alignment of the caster which is set on an axle when pinion angle is set. Unless you get an axle built for your specific intended pinion angle, you can end up with a very uncontrollable vehicle on the road. Now the other option would be to measure the original pinion angle that the axle was setup for and then what your intended pinion angle would be. Cut off the outer flanges and rotate them by that amount.
The other thing that I would like to point out is that I would have choosen to mount the shackles in the front and the solid mount in the rear. This is due to the movement of the axle during flex and acceleration. With the shackles in the back, the axle will swing forward even minutely, but this will do more to complicate driveline angles that are already pretty complicated. By putting the shackles in the front, the axle will swing towards the back, maintaining better driveline angles as well as cause less of a length change in the front driveshaft. The impact of this will be more pronounced the higher you go.
Here is some information on steering geometry: Steering Geometry - Offroaders.com
Another good article at Offroaders.com is the one on shackles: Shackle Length and Spring Movement - Offroaders.com
Old Feb 20, 2008 | 09:36 PM
i just got the front diff. i got the complete with all brackets. i am going to use the coil over suspension. the guy i got the front diff from has a jeep with the rough countr 6 inch lift. the way it is built i can copy it so i can adjust the angle of the diff for the caster. all i will need to buy is longer coil springs and some tubing to mount the shock and coil. he also had 4 real nice 10 inch rims to fit the front diff. i will have to get spacers for the rear but was planning anyway for the offset. am looking at a set of used 33 for the truck. the rear i am just gonna do a spring over. then buy matching gears rear and front . i am gonna drop to 4.11.
*Combining posts. Please use the EDIT function if no one has replied since your last post, thanks. TBB
thanks . that geometry site will help alot thank you
Old Feb 20, 2008 | 09:38 PM
Keeler
Lifting Tech
22
May 29, 2010 03:53 AM
blazinUP
Tires and Wheels
May 14, 2010 08:06 PM
ghost
Jun 3, 2009 02:44 AM
TripleBlackBlazer
62
May 12, 2008 09:46 PM
