96 4x4 front end issue...New poster
Old Mar 27, 2011 | 11:21 AM
bobbye's Avatar
bobbye is an unknown quantity at this point
Unhappy 96 4x4 front end issue...New poster
I'm fairly new to the forum, made a couple posts, but just gather all the info by doing a search first, so many times I haven't had to post. I did a search on this and found a ton of info, but I still can't figure out what I did wrong. Here goes:
Replaced the LH (drivers side) lower control arm and shock. (was going to do both sides, but it got too late to do the RH) .Removed tension from the torsion bar with a 2 jaw puller, removed all the nuts/bolts/hardware associated with the LCA and took the entire assembly off and put the new one in. Everything seemed to go relatively well. upon putting the vehicle back on the ground the LH side sits WAY too low. Tried adjusting the torsion bar bolt, but it's bottomed all the way in and it still sits too low. The one thing I did not do was remove the bar from the adjuster link (its rusted in there pretty good) we just let it hang and removed the LCA end and replaced it. Could this be where we went wrong? Should it be completely removed from the mount and the LCA. I'm planning on doing the RH side tonight so any input would be helpful.
Thanks, Bob
Old Mar 27, 2011 | 05:24 PM
Did you make sure to put the torsion bar back in the same orientation as it was in the other arm? You may have to remove the LCA again and rotate the torsion bar one flat further.
Old Mar 28, 2011 | 09:03 AM
bobbye's Avatar
Thats what I was thinking was the case, however I was HOPING that it wasn't. I THOUGHT we had it in the same orientation, but then again at 1 a.m. we probably missed it by a flat or 2. Thanks. I guess I have my work cut out for me this week. Why does this stuff always happen when its cold? Couldn't happen when it's nice and sunny/warm.
Old Apr 3, 2011 | 12:26 PM
bobbye's Avatar
Tried today to "move" the torsion bar to no avail. It's rusted/stuck. Its been soaking in PB Blaster for the last 2 days and it wont budge. Is there a trick or something to getting these out? I'm at my wits end! I can't get in there straight with anything to whack on it 'cause the gas tank is in the way. I've never had as much trouble as I have with this vehicle! At this point I'm ready to scrap the damn truck-I dont think its worth it anymore, especially when I still have to do the other side too. Please help!
Old Apr 3, 2011 | 01:59 PM
bobbye's Avatar
UPDATE:
I walked away from it and cooled down(I was getting pi%%ed off). I went back out side and with a little persuasion, managed to get it out of the adjuster arm. Evverything came out with about 200 blows from a hammer and punch. I did have to lower the crossmember that holds it all to get a better shot with the punch, but it worked. Now if it will all go back together nicely, I'll have it made. (although I'm still thinking it isnt worth it... LOL)
Actually, now I'm actually looking forward to doing the other side.
Old Apr 3, 2011 | 03:06 PM
warthogdriver's Avatar
glad to hear it is working out for you after all...those torsion bars are a real p.i.t.a.
mark the orientation on second one ...just kidding
should toss some anti-seize on it while its out...never know.
Old Apr 3, 2011 | 07:10 PM
bobbye's Avatar
Yep. I put anti-sieze on the LCA, adjuster link and both ends of the bar. I got down to having to put in cotter pins and the end links when I dropped the spacer for the links. Couldn't find it, so I figured I'd call it a night. LOL. Been one hell of a day.
Major Tom
Jan 16, 2012 11:02 PM
charlie_r
Sep 2, 2011 05:16 AM
XBlazer01
May 21, 2009 03:20 AM
Vermilion
Apr 14, 2009 07:37 PM
martybook
Mar 6, 2008 10:03 PM
