96 S10 Stuck ball joint
Old Jul 11, 2010 | 09:49 AM
kiddswifts10's Avatar
kiddswifts10 is on a distinguished road
Default 96 S10 Stuck ball joint
Im loosing my mind! Im having issues removing the upper ball joint. IT was the original from dealer (no bolts) The driver side came off with no problems but the passenger side is starting to get the best of me. I drilled them out, tried the fork idea still no budge. I ended up prying the top half off BUT now just the bolt is stuck. I cant move the car now because its disconnected from the spindle. I know it was a bad move but I need help from you wizards
Old Jul 11, 2010 | 10:14 AM
taba5's Avatar
taba5 is on a distinguished road
Is the castle nut still on the ball joint stud? if so take big vice grips and clap down as best you can on the stud and try and remove the castle nut that way.
My upper driver did this and the stud itself just rotated in the joint, so everytime I tried to turn the castle nut off it just spun its happy lil **** off. After the castle nut itself was off I just tapped the bottom of the stud with my trusty "BFH" and it flew out.
Old Jul 11, 2010 | 10:29 AM
Default Broken upper ball joint
This is a pic of a guy that had almost the same issue except i got my upper part of the ball joint out. The part where his is labeled B is where im F-ed at....
josemateos
Feb 18, 2014 10:00 AM
Guntheone
Dec 4, 2010 05:59 PM
ejoy1220
Oct 8, 2006 06:45 PM
timetoblaze
Apr 17, 2006 12:47 PM
00ZR2BLZRGUY
Suspension Tech
Jan 1, 2006 08:12 PM
