97 Blazer LT Chattering Noise Problem, Front Right.
Old Dec 22, 2015 | 07:23 AM
Scarakus's Avatar
Scarakus is on a distinguished road
Unhappy 97 Blazer LT Chattering Noise Problem, Front Right.
97 Blazer LT Chattering Noise Problem, front right...
i have a bad chatter noise problem, front right. i changed out the wheel bearing, CV axle, upper & lower *****, sway link, and steering link, so everything is new, but I still have the noise.
it sounds like speed bumps, and it kicks in and out at various speeds, but is worst at 55.
i was concerned about the inner spline being loose...
so i did did a quick video showing it, and also did a sound byte video, below...
I'm hoping someone might be able to help diagnose my problem?
Here is the shaft video;
And here is the Sound Byte Video;
Old Dec 22, 2015 | 07:32 AM
Scarakus's Avatar
I've been Searching the forum and found a few similer threads, going to investigate...
here were the threads i found;
97 Roaring noise
fast flapping noise
Old Dec 22, 2015 | 08:27 AM
Scarakus's Avatar
well as much as i hated to do it, i put it 4wd, the noise is now gone, but now it's stuck in 4 hi, as it does every time i use it.
hopefully it might pop out soon eventually, then i'll find out if the noise was happening because the 4wd was partially engaged..?
TFitzy16
Jun 3, 2015 07:18 PM
jesusarendon
Oct 21, 2012 03:07 AM
jburke
May 1, 2011 04:17 PM
JamesVengeance
Jun 13, 2009 02:36 PM
redpeppers
Apr 7, 2007 04:55 AM
