98 jimmy rear end issues
Old Apr 3, 2008 | 07:38 PM
cbash1979's Avatar
cbash1979 is an unknown quantity at this point
Default 98 jimmy rear end issues
ok i did the u joints put in a new pinion and ring gears drives fine between 0-25 mph
anything above that and the rear vibrates pretty rough been threw this forum for about 4 hours trying to look threw all the post about rear ends and couldnt find anything on what my problem is if i could get some advice before i go out and spend even more money to fix it cuz i miss driving it
Old Apr 3, 2008 | 07:41 PM
TripleBlackBlazer's Avatar
Default RE: 98 jimmy rear end issues
Was the driveshaft indexed before you took it out to put the u-joints in? If not, pull the bolts of the rear, flip the driveshaft 180 degrees and reinstall.
Check out THIS THREAD for more info.
Old Apr 3, 2008 | 07:46 PM
Did you check the contact patch and engagement on the ring/pinion when you set up the rear?
Old Apr 3, 2008 | 07:48 PM
cbash1979's Avatar
ORIGINAL: TripleBlackBlazer
yea i did that already thinking that was the problem it isnt my first time working with drive shafts
Old Apr 3, 2008 | 07:56 PM
Just trying to cover the basics. I have no clue what a contact patch or engagement is and Kyle knows his stuff...The only experience I have with a vibration and u-joints is a driveshaft that isn't indexed.
Hope you find the culprit!
Old Apr 3, 2008 | 08:12 PM
cbash1979's Avatar
ORIGINAL: swartlkk
nope didnt do that ill do that first thing saturday morning been driving my 96 bonneville since it started vibrating like this now i wanna drive it again i miss it but then again if i cant fix it ill just sell it as is
Old Apr 3, 2008 | 08:17 PM
So does that mean that you didn't check back lash, etc either?
THIS LINK should provide you with the required setup for a rear end to maximize it's life.
Old Apr 3, 2008 | 08:28 PM
cbash1979's Avatar
ORIGINAL: swartlkk
thanks for the info now ill print the page so i have it and figure it all out and see where my muff up is
Old Apr 3, 2008 | 08:39 PM
That is just the first thing I found that had the steps. There are better pages that detail things better if you search around the internet a bit more.
doktornasty
Nov 3, 2013 03:12 AM
brino1
Feb 25, 2011 08:05 PM
l3igl3ang
Jan 18, 2009 09:03 PM
20blazerXtreme02
Nov 15, 2007 11:44 PM
johnnyb
Nov 6, 2007 02:41 PM
