Tire rubbing
Old Mar 31, 2008 | 06:52 PM
ryno's Avatar
ryno is an unknown quantity at this point
Default Tire rubbing
HEy guys, i havnt been on in a while. BUt i gotta question. I got new wheels and tires, Rock crawlers and 30x9.50 BFG ATs. It rubs on the passn. side. It didnt use to do this but when i got an alignment the guy said he had to cant the right front wheel back. And now it rubs! WTF? Should i just get it alligned again?
Old Mar 31, 2008 | 07:28 PM
WolfPack's Avatar
Default RE: Tire rubbing
You might have a sagging t-bar on the right side. Measure from the ground to the bottom of the fender well at the highest point (both sides). If the pass. side is lower (which it probably is), just get under there and crank up the pass. side torsion bar. It'll fix the sag, and since you're only adjusting .25' or whatever it needs, you're not risking the ball joints/cv's much if at all.
Old Mar 31, 2008 | 07:34 PM
ryno's Avatar
I will measure it and see. BUt you dont think that it being canted back affects it?
Old Mar 31, 2008 | 07:39 PM
WolfPack's Avatar
It very well could, but I've heard alot more blazers with sagging t-bars on the passenger side than any other issue.
I could be wrong though, but it's worth a check
Old Mar 31, 2008 | 08:37 PM
ryno's Avatar
OK cool. Well i will check that as soon as the streets dry from this wonderfull coloradoweather
Old Apr 2, 2008 | 07:08 PM
ryno's Avatar
Well, today i measured the height on both sides and they are the same height. haha. so whats my plan of action now. I need shocks, so do you think that would raise it at all?
Old Apr 2, 2008 | 08:13 PM
Millertime21's Avatar
Millertime21 is an unknown quantity at this point
Does the pass. tire stick out a little farther than the drivers? I know my blazer needs new ball joints and the pass. side tire sticks out about an inch morethan the drivers.Before I trimmed my fenders only my pass. side would rub ocassionally.
Old Apr 2, 2008 | 08:47 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
What was the height you measured and was there even like .1" difference between the sides? Even a very slight extra sag on the right might be enough to make it rub. Also for kicks have you jacked up the right wheel and done a nice shake to check for worn out frontend parts?
Old Apr 3, 2008 | 10:34 PM
ryno's Avatar
Well. I just did the ball joints not 6 months ago, and the height on the rightis so close to the left i cant tell if there is a major difference. why wouldball joints make a difference anyway.
simmonsnick
Tires and Wheels
16
Jan 29, 2017 11:55 AM
cr8390
28
Jun 13, 2009 10:43 AM
D_Beezy18
Tires and Wheels
Mar 2, 2009 09:26 PM
gstrat323
Tires and Wheels
Dec 12, 2008 11:09 AM
blazerboy30
May 27, 2008 10:22 PM
