ABS light
Old Jul 7, 2010 | 08:00 AM
bmann383's Avatar
bmann383 is on a distinguished road
Default ABS light
On my 2000 ZR2 blazer my abs light keeps comming on. Mostly when its wet out or when I back up a bit fast and put the brakes on. I took to a local garage and they scanned it and told me the abs unit was probably bad and wanted to charge me 600.00 to fix it and no guarantee.
I went on Ebay and found one for my blazer and replaced it..
The problem is still there.
I have traced the wires on the front wheels sensore up to the unit and the wires look good.
Anybody else have this problem?
Thanks
Old Jul 7, 2010 | 09:05 AM
84BlazerS10's Avatar
Does it do it when you push on the brakes hard or is it just randomly doing it while driving or...?
Because if your putting on the brakes hard to stop the car after backing out fast it will engage as ABS is designed to prevent wheel lock up modulating the brake pressure during an emergency stop.
Old Jul 9, 2010 | 07:38 AM
bmann383's Avatar
Some times it comes on when I start the Blazer. Other times when I back up. Sometimes just while I'm driving, but mostly at start up.
Old Jul 9, 2010 | 11:25 AM
MUDBLAZERX's Avatar
MUDBLAZERX is on a distinguished road
wheel speed sen. you will have to pull the hubs to get them off some years you can just buy the seed sen. others you have to buy the hub as well bc they r made as one
Old Jul 10, 2010 | 08:50 PM
Hanr3's Avatar
The ABS light on means that the ABS unit has been disabled. So when you make an emergency stop your tires will lock up and you will slide. Back in the day we used to pump the brakes to stop. Pumping the brakes does several things, stops the truck in a controlled fashin, plus the time you let off the brakes allows the rotors time to cool off so you dont warp them.
Tinted
Mar 15, 2012 02:56 PM
damageinc98
Jul 12, 2010 10:47 PM
stormshadow1
Apr 23, 2009 09:46 AM
95_Blazer
Dec 6, 2007 09:44 AM
Deezy
Oct 25, 2007 08:58 PM
