ABS question
Old Mar 15, 2009 | 08:50 AM
jeffreys25's Avatar
jeffreys25 is an unknown quantity at this point
Default ABS question
When my ABS system is plugged the motor sounds like it is constantly working, is there anything I should look for so the ABS would work?
Thanks,
Jeff
Old Mar 15, 2009 | 05:04 PM
Vehicle information???
Old Mar 15, 2009 | 10:33 PM
jeffreys25's Avatar
I have a 2001 2dr blazer LS 4x4
Old Mar 16, 2009 | 09:19 AM
Just for some clarification, if you install the fuse, the ABS pump is active even while stopped? Is it active with the key off? Is it active with the key in the RUN position, but engine off?
Old Mar 16, 2009 | 04:18 PM
jeffreys25's Avatar
the abs system is constantly running, even if the keys are out of the ignition, when i replaced the fuse the system still continues to run
Old Mar 16, 2009 | 04:48 PM
You have crossed wires somewhere in the system then or a bad ABS control module... Wiring problems suck to diagnose.
Tinted
Mar 15, 2012 02:56 PM
iamchevyman5
Feb 28, 2011 04:35 PM
stormshadow1
Apr 23, 2009 09:46 AM
01BlazerLT
Feb 1, 2008 03:23 AM
metalhead
Sep 13, 2007 10:26 AM
