abs code question
Old Jan 28, 2008 | 12:31 PM
01BlazerLT's Avatar
01BlazerLT is an unknown quantity at this point
Default abs code question
Ok I took my truck to a local mechanic and he ran a diagnositc and said the truck is throwing a P1000 code, the ABS light is on but the truck performs properly. Anyone know what a P1000 code is? TIA
Old Jan 28, 2008 | 07:37 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: abs code question
Well I did not find a P1000 code at all. I would see if they would tell you exactly what the code was. ABS codes should start with a C also, P codes usually mean powertrain, I.E.: engine, trans, t-case. If you got us that code we could help you out!!
Old Jan 31, 2008 | 07:34 AM
01BlazerLT's Avatar
I fixed the problem on my own. On a whim I decided to check the ABS fuse in the panel to the left of the dash, I pulled the fuse out and one of the prongs was broken off, replaced the fuse and the problem the abs light is now off. My stupid question is why wouldn't the mechanic have looked at this, oh well cheap fix!
Old Jan 31, 2008 | 07:39 AM
Sometimes the simplest things get overlooked. Glad you got it fixed!
Old Feb 1, 2008 | 03:23 AM
Chevy Lover's Avatar
Unfortunately I have seen many times when mechanics don't start with the basics and can spend a lot of time on diagnosis before they go back and start at the beginning.
Kinda like the guy who replaces his ball joints to repair his steering problem and then checks the air pressure in the tires,only to find one low tire with a nail in it, after a full day and many $$$ spent. [:@]
Tinted
Mar 15, 2012 02:56 PM
iamchevyman5
Feb 28, 2011 04:35 PM
stormshadow1
Apr 23, 2009 09:46 AM
88blackzcand95blazer
May 27, 2008 03:38 AM
tom04841
Nov 29, 2007 08:00 AM
