add a leaf kits
add a leaf kits
Whats the difference between the long and short add a leaf kits? Whats the best?
RE: add a leaf kits
Short adda leafs are cheaper... they go under the leaf pack. They're also a bit stiffer than the long add a leafs.
I'd recommend long add a leafs. They're a bit more work to install, because they go between the top two leafs in the pack, but they distribute the load over a larger area on the spring pack, and aren't as rough on the ride.
RE: add a leaf kits
yup jigg's right. I just installed the long add-a-leafs. The shorts are known to give a real bumpy ride. The longs were actually cheaper. only by about 10 bucks though. They gave me just the amount of lift I was looking for. Go for it.
RE: add a leaf kits
how high should the back of a 2000 2dr blazer be? i think mine has sagged a little. which long add a leaf do you recommend and what is involved in the installation?
RE: add a leaf kits
add a leafs will work even though the spring pack is under the axle
hurleyii
03-18-2014 07:23 AM
lennyblazer
07-06-2007 11:10 PM
