auto 4wd question
Old 12-18-2018, 08:56 AM
satman52's Avatar
satman52 is on a distinguished road
Default auto 4wd question
I have a 2001 LS 4 dr Blazer with the 4 button system with NP8 transfer case. In 2HI the front drive shaft is turning all the time. It's my understanding that it not supposed to except in Auto 4wd. I have replaced the control module behind the kick panel and the 4 button assembly in the dash. How is that controlled, is it electrical or vacuum controlled. What would cause this? Appreciate any advice.
Old 12-18-2018, 09:36 AM
LesMyer's Avatar
LesMyer will become famous soon enough
The front driveshaft will always turn in a NP8. There are internal clutches in the transfer case that provide varying amounts of torque on the front driveshaft (even a little in 2 hi). However, in 2 hi the front axle is not engaged. It's normal!
Old 12-18-2018, 08:13 PM
satman52's Avatar
Thanks for the reply, a local mechanic told me the front drive shaft should not turn in 2hi, only in 4wd or auto 4wd. I realize the front axle isn't engaged in auto 4wd but I was told that with the front shaft spinning all the time it would reduce gas mileage and cause undue wear to something in the front differential. Thanks for the answer
lmo
04-28-2013 08:50 AM
Charles Hines
11-03-2012 09:35 AM
vede
06-29-2012 02:38 PM
Survivor
05-25-2010 11:35 PM
mikeymo67
11-07-2008 12:22 PM
Quick Reply: auto 4wd question
