auto 4wd
Old Apr 27, 2013 | 12:52 PM
lmo's Avatar
lmo
lmo is an unknown quantity at this point
Default auto 4wd
Hello I Have a 2001 s-10 blazer w auto 4wd the 4 push button kind and was wondering if the front drive shaft is supposed to turn when in 2hi? All of the components of the 4wd system seem to be working properly just wondering if its because it is an auto 4wd. Seems to be dropping my gas mileage from a standard three button 4wd model. Any imput would be appreciated. Thank you
Old Apr 27, 2013 | 01:26 PM
okiedoak20's Avatar
i have the same as you and from what i have learned the front DS does indeed turn all the time, somthing about the clutch packs in the transfer case, and mine does also turn all the time also.. FYI though, the fluid is a special Autotrac II fluid from GM, its blue in color and part # is 88900402
and costs about 7-8$ a quart..
Old Apr 27, 2013 | 01:58 PM
lmo's Avatar
lmo
Thank you
Old Apr 27, 2013 | 03:49 PM
okiedoak20's Avatar
no problem, on the 3 button style T/C's the front DS does not turn, and i would guess the gas mileage would be slightly better, but not like way different, before the larger tires i installed i was getting 19 mpg hiway, 16-17 city, but in 4wd close to 8-9mpg, real bad in 4wd
Old Apr 27, 2013 | 06:58 PM
lmo's Avatar
lmo
Mine gets around 16 to 18 at best. I know a friend who has one with regular 4x4 and he gets 21 to 23 all the time so was just wondering why. Thanks alot for the info!
Old Apr 28, 2013 | 06:42 AM
coolasice's Avatar
coolasice will become famous soon enough
i believe the shaft is turning all the time regardless of auto or non as it needs to keep speed with the transfercase for on the fly engagement, it just is not powered by the transfercase unless 4x4 is call for.
Old Apr 28, 2013 | 08:50 AM
lmo's Avatar
lmo
That makes sense thank you
Blazeme
Jan 24, 2015 06:08 PM
blazen_red_4x4
Jun 1, 2014 05:43 PM
LannyL81
Aug 8, 2010 01:01 PM
2000_BlzrLT
Jul 29, 2007 02:15 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
