Axles on a SAS
Old May 27, 2013 | 11:00 PM
abig84's Avatar
i would think the 14 bolt dana 60 combo would be fine especially in that light of a truck, theres so many people running those under fullsized trucks with 44s. a ford 9 inch might be a good choice for a rear axle if you want to go a bit smaller.
i thought about doing a big s10 like this but thought nah, im glad i did 33s have been just as fun as ive had in the past with full size trucks and 38s, way more nimble, quicker, can actually see where youre going.
Old May 28, 2013 | 01:35 PM
Diaita's Avatar
Rockwells are way too big for a 4.3 and 44s. Most guys run 1 ton stuff in their rock bouncers, and I challenge you to beat a Blazer/Jimmy that hard.
Old May 28, 2013 | 03:58 PM
Jamaroon's Avatar
The guy I mentioned was a 4 door blazer with the 4.3......
Old May 28, 2013 | 06:28 PM
Diaita's Avatar
Impressive!
Old May 28, 2013 | 10:08 PM
Jamaroon's Avatar
Yeah I don't have a clue how he managed that. I still think 44's would be about the max I would run for a stock D60, if you're throwing a bunch of money at it then sure 44's no problem and even bigger. RCV warranties up to a 49 for their D60 shafts so if you want more than a 44" tire I would be saving my pennies for those.
Old May 30, 2013 | 12:19 AM
greenslug's Avatar
greenslug is on a distinguished road
yeah, i want to gear down, limited slip the rear, lock the front, use a doubler on a 203/205 tcase for a 4:1 low range and 1 tons i think. might end up doing a 5.7 v8 swap if im power starved too. once this ball gets rolling, ill start a build thread. currently, just saving for the build, and researching the best options so i wont have to do 3 builds due to weak parts.
Old May 30, 2013 | 07:13 PM
cleburne red's Avatar
Originally Posted by greenslug
...and researching the best options so i wont have to do 3 builds due to weak parts.
Good idea!! I finally figured that out, myself. I would always cheap out, and end up spending as much, if not more to patch up the cheap parts than it would have cost to just buy the right part to begin with.
Old Jun 3, 2013 | 12:37 AM
greenslug's Avatar
exactly! nothing is worse! currently, i just do mods i can on the cheap, like shackles or new exhaust. little things that cost under $100.
Old Jun 5, 2013 | 08:33 AM
Kpearson's Avatar
Kpearson is on a distinguished road
While I was doing some searching for what to get for my next project on my blazer I came across this. It was published in a 4 wheeler magazine in Feb 2009
Axles Revealed: Choosing the Right Axle for Your Upgrade
Maybe that might help with the choices?
Old Jun 5, 2013 | 12:21 PM
greenslug's Avatar
good link! thanks, clears up a few things. im most likely going to run one tons, unless i find 2.5 rockwells. my theory is that you cant really be too strong. the 4.3 might be ditched after the SAS, looking at a 5.7 and if possible, a 6.0 with a super in it.
