Bad Rear Wheel Bearing, can I still use this diff?
Old Nov 5, 2011 | 01:07 AM
DaveRush's Avatar
DaveRush is on a distinguished road
Default Bad Rear Wheel Bearing, can I still use this diff?
'97 Blazer 4door, 4x4, LT. So the bearing was bad. Really bad. Inches of play bad.
I get the axle out, and this is what greets me:
Yeah, I need to replace this shaft.
Compare with the other side:
So this was the temporary bearing surface, not as bad as I was expecting:
I can fix those things, but my question is this: Can I still use this diff or must it be replaced?
This is the magnet, and there's a lot more in the gear oil. Even if it all came from the bearing's death/the shaft's weight loss and NOT from the gears... did having this in the oil damage the diff components?
Here are some pics of the diff, I'm not finding a lot of metal shavings on it:
These spots aren't metal flakes, the camera reflected funny.
Tell me what you think, is it re-usable if I clean it up? The gears look fine, there aren't any teeth missing or anything.
Old Nov 5, 2011 | 02:37 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
if it where me i would re use it if no teeth are damaged, should be no problem. i might try and clean it out a little tho. is that a G80? looks like it.
Old Nov 5, 2011 | 02:51 AM
DaveRush's Avatar
I've given it a can of brake cleaner's worth, and it does look less brown.
It is a g80, with 3.73 gears.
I'll replace the bad bearing and run it as is with new oil, doing another fresh gear oil change soon. If the other bearing is bad, it'll get done then.
Old Nov 5, 2011 | 06:30 AM
coolasice's Avatar
coolasice will become famous soon enough
I'd do both anyway, little security for the future
blazinjay83
Dec 30, 2023 08:31 AM
89Recon
Lowering Tech
Dec 24, 2011 03:17 PM
ZLover4Life
Jan 19, 2010 10:28 AM
mikes93s10blazer
Aug 16, 2009 07:48 PM
yazan84
Mar 10, 2008 06:53 PM
