Ball Joint Urban Legend?
Old Jan 30, 2012 | 12:49 PM
spittybays
Guest
Posts: n/a
Default Ball Joint Urban Legend?
95 three button. Just did upper and lowers on both sides about a month ago. 4x4 just went (again) now I'm down to the thrust washers in the front diff. I see there as many so called easy ways of getting the CV axel out as Carter has pills. Just taking the whole dammn thing apart, would love to save the new upper ball. I have been told you can make it release by smacking both sides with two hammers at the same time, kind of like releasing the steering. Any feelings on this. Thank's Jeff.
Old Jan 30, 2012 | 05:26 PM
bigkhans's Avatar
bigkhans is on a distinguished road
I've never tried using two hammers at once, but it might work more efficiently than using only one bfh. I'll soon find out as i will be replacing all four ball joints on my Blazer. The previous owner failed to notice that they needed replacing.
Old Jan 30, 2012 | 05:36 PM
war00's Avatar
war00 is on a distinguished road
i have never used a tool to release the ball joints or tie rods. i always take out the cotter pin, loosen the nut, than give the knuckle good couple hits with a hammer where the bj passes thru. works everytime
Old Jan 30, 2012 | 05:47 PM
Xenon's Avatar
Xenon is on a distinguished road
x2. And if one hammer doesn't do it, 2 almost always does...
Old Jan 30, 2012 | 08:53 PM
spittybays
Guest
Posts: n/a
Thank you. Love large pair of hammers.
Old Jan 31, 2012 | 07:31 AM
mike mtzr2's Avatar
mike mtzr2 is on a distinguished road
2 hammers never failed me as long as they hit at the same time.
Old Jan 31, 2012 | 07:50 AM
bigkhans's Avatar
And the intended target, vs knuckles or finger tips.
Old Jan 31, 2012 | 07:54 AM
pettyfog's Avatar
Ohfucrineoutloud!
You DONT "hit with two hammers at same time"!!!!!! You hold one against one side of the knuckle, and smack the other side with your dominant arm/hand.
It's the ONLY way I use to remove tie rod/ ball joints for the last thirty years.
Think 'anvil'
I've found the best combo is the head of a ten pound sledge and a framing hammer.
And I've done a few. If you dont beleive it works, ask any blacksmith. If you think it might damage the knuckle.. again .. ask the blacksmith, it wont.
The steel alloy used to make steering knuckles used to be called 'Malleable Iron' Which means you can beat the **** out of it before it cracks.
Old Jan 31, 2012 | 10:06 AM
spittybays
Guest
Posts: n/a
Over, done. Small sledge and framer worked like a charm. Thank you one and all. Pickel fork has been retired.
Old Jan 31, 2012 | 04:03 PM
neo71665's Avatar
First I've ever heard the 2 hammer trick. I've always used one.
ABN31B
Apr 2, 2017 03:51 PM
josemateos
Feb 18, 2014 10:00 AM
1sikBLAZR
Jul 14, 2012 06:35 PM
Guntheone
Dec 4, 2010 05:59 PM
00ZR2BLZRGUY
Suspension Tech
Jan 1, 2006 08:12 PM
