ball joints
Old Oct 19, 2011 | 02:27 PM
Little Roober's Avatar
Little Roober is on a distinguished road
Front Lower Ball Joint Installation Instructions Chevy GMC S-10 S15 - 1AAuto.com - YouTube
There's a part two also. It should come up in related vids. That plus the chilton's or...the other one (also forgot the name) manual is all I needed for my first time through it.
The half shaft should pop right out of the knuckle. Btw, power performance also makes good steering and suspension parts.
EDIT: Also, you're gunna get scolded for not using the edit button to combine consecutive posts. Haha. Just a heads up.
Old Oct 19, 2011 | 03:37 PM
pettyfog's Avatar
That's an excellent video.. he does good stuff.
- but-
1. The usual quibble - like how he just taps the tapered pins up.. oh well.
2. NEVER use Linseed oil on brake surfaces, turpentine or even mineral spirits . Any oils at all will glaze the pad surfaces.
If it says on label 'can be used to thin oil based paints', dont use it. I have NO idea where he got that. Did a search though and some brit said coat rusty shields with linseed oil, on an old M-B, to prevent further rusting but he cautioned to not let it get on rotors or pads. So it is only common sense if linseed soaks into rust, it'll soak into pads.
- if you dont have brake cleaner, then use rubbing alcohol {90% is best} to clean off hand prints. It's what I use to get the preservative off new rotors.
LoLoS10Blazer87
Suspension Tech
Sep 19, 2008 07:43 PM
tom1337
17
Mar 12, 2006 10:44 PM
TDQ
Suspension Tech
Jan 9, 2006 01:50 AM
alexbtango15
Suspension Tech
Jan 7, 2006 01:06 AM
hdlogistics
Suspension Tech
Dec 2, 2005 10:53 AM
