balljoints u/lbj master pro brand
Old Oct 10, 2011 | 01:48 PM
614blazer's Avatar
614blazer is on a distinguished road
Exclamation balljoints u/lbj master pro brand
i bought upper and lower ball joints from oriley auto parts and brand name is master pro. and i went to replace my upper and the way they are made is the dust shiel/grease boot come off seperate from the joint with a backing plate. so i was wondering to you put the shield plate from the top along with the joint and tap it in or put the shield on the bottom of the control arm and the joint on the top and bolt it in. i have a 1998 blazer 4x4 and never done ball joints. need help asap thanks
Old Oct 10, 2011 | 03:11 PM
bromanjr's Avatar
bromanjr is on a distinguished road
No tapping should be required, the metal dust shield and rubber boot should go on below the arm after the joint is inserted from the top. The bolts hold it all together. The existing joints should have been installed this way.
Silver00LT
14
Feb 20, 2011 06:22 AM
dougs10
Dec 14, 2010 03:24 PM
jimdian
Feb 9, 2010 09:21 PM
jdell1107
Tires and Wheels
May 14, 2009 08:59 AM
KLBlazer07
Jan 16, 2007 02:27 AM
