In blizzard. 4x4 doesnt work. Help
Old Nov 29, 2022 | 06:02 PM
Blue4byblazer's Avatar
Blue4byblazer is on a distinguished road
Default In blizzard. 4x4 doesnt work. Help
Hey yall
Freak blizzard just hit where i live. Went to use 4x4 on this 84 s10 blazer 2.8 auto i just bought. 4 hi doesnt work and needs to be "held" in place for light to come on. 4 low works but whines like a banshee. i know i need new cv boots as well. Do you guys think its the switch on the transfer case or the actuator beneath the battery holder. extemely time sensitive i need this fixed ASAP.
Thank you all in advance for your help!
Old Nov 30, 2022 | 12:34 PM
84_HOS's Avatar
84_HOS is on a distinguished road
Hard to tell what the issue is. If 4 Low works, then the vacuum system and actuator is probably ok. If I remember right that switch did one thing, whether you were in HI or LOW. It was either popped out when the lever moved allowing vacuum to pull one way or was pushed in and let vacuum pull the other way. Id guess the 4 Hi issue is a linkage adjustment issue. Does it go into gear (i.e. 4 Hi) when you hold the lever forward?
Old Nov 30, 2022 | 12:52 PM
it doesn't work in 4 hi or 4 low now it seems
Old Nov 30, 2022 | 01:19 PM
84_HOS's Avatar
On mine the vacuum actuator is close to the battery and easy to get to. you could get some cheap vacuum hose and try to find a vacuum port to borrow and see if you can engage the actuator to pull the front diff collar over. Hopefully that's it, you can make a cheap work around till better weather. If that isn't the problem its in the T-case, possibly the linkage not engaging fully. To check the linkage you probably want a dry piece of pavement to crawl under it.
BlackBastard
14
Nov 15, 2013 10:47 PM
ikeroad
Dec 9, 2011 02:05 PM
2tone96
Dec 14, 2009 01:20 PM
WisdomRacing
Mar 28, 2009 08:33 PM
Dog
Dec 26, 2008 08:09 PM
